InterMurph
Jan 18, 2021Guide
Brand new RAX120 router stops responding multiple times per day, requires reboot
I just replaced my AC1750 router with a RAX120. Paired with my CM1200 cable modem, it gets the full 1 GB/s download rate on my Xfinity cable. It's great. When it works. The problem: multiple t...
InterMurph
Jan 26, 2021Guide
And of course, it just seized up on me.
And there is literally nothing I can do to diagnose it while it is in this state; I can't ping it, log into it, or anything.
This is so frustrating.
mudbone
May 07, 2021Apprentice
Make sure the router auto firmware update is disabled. Last week when they both crashed rebooting would not fix them so I ended up having to factory reset both of them. When I reviewed the log on one of the routers (with wired PC) before the reset it looked like it had tried to update the firmware to the same version! Also I found that if you set the "Always enable Fan" in the hidden page "http://192.168.1.1/debug.htm" only check the box. I was clicking one of the save buttons and its not necessary and may even be harmful. It will uncheck itself though when it reboots so you will have to keep setting it. It is a way to tell if it rebooted. On my AP I can tell because the IP changes.
- JTaylorIVMay 07, 2021Guide
Same issue.. Brand new router, RAX120v2 initializes randomly..
I bought a RAX102v2 and shortly after I bought the router I was experiencing the similar problem. Opened a couple of tickets with support, with no resolution to the router initializing or rebooting.
Issue: Router randomly performs an initialization
Firmware V1.2.0.16
Tried
- Fully reset, clear, update firmware from PC directly connected to router. Manually entered the configuration. Did not upload a saved config. No change
- Modified the MTU to 1492 (from 1500) – No Change
- Disabled AX – No Change
- Changed Wireless from Auto to settings provided by tech. No Change
- 2.4 Ghz to 11 (previously Auto)
- 5 Ghx to 161 (previously 153)
- I had the power supply connected to an APC Smart 1500 UPS. Asked to move to a different outlet. Did so, no change
- Changed the DNS from my ISP to Google’s DNS; 8.8.8.8 and 8.8.4.4 No Change
- Removed devices connected to the ethernet ports.
- Changed cables and the ethernet cable between the router and modem. No Change.
I thought that the router may be experiencing an exploit from a hacker who is able to reset the router. So, I disconnected the internet connection. No Change
My network is simple. Approximately 30 devices connected: Three Amazon devices, two TV’s, Water sprinkler, two thermostats plus others passive devices. Computers, two normal computers, no gaming. Other devices, iPhones and iPads. Nothing spectacular. The Modem, NetGear
Thought it may be a heat problem. Added a small fan to help with cooling. Also looked into the router and set the internal fan to constant on - 192.168.1.1/debug.htm No change. Also the fan resets back to auto when the router initializes.
From the debug info.. Also captured the following. Network Session Total seems maxed.
Basic Information
CPU Load
11.194%
Memory Usage(Used/Total)
459MB/869MB
Flash Usage(Used/Total)
233MB/512MB
Network Session(Active/Total)
3218/65536
I have not tried to adjust the following parameters in the debug menu
2.4GHz Beacon Interval ms(20-100)
2.4GHz DTIM (1-255)
5GHz Beacon Interval ms(20-100)
5GHz DTIM (1-255)Since I bought the router at Best Buy, I took the pages of notes from the ticket to the Geek Squad. Looked for any recommendations. Since NetGear technical support’s recommendations failed to resolve and it seemed that their only solution was to reflash the firmware and start from scratch, which did not seem to resolve my problem. The Geek Squad replaced the router with the exact same router and will send the router back to NetGear.
Well, the second router is doing the exact same thing. If it is my fault, glad to admit but I cannot find why this router would reboot.
I previously had a Motorola router, which was slow and I wanted something with better performance which the RAX120 seems to fit the bill.
Any suggestions welcome.
- InterMurphMay 07, 2021Guide
I suggest you buy the Asus ROG GT-AX11000 router. That's what I did, and it just worked perfectly since I got it set up.
There is something basically wrong with the code in this Netgear router, and they haven't figured it out yet (or even acknowledged it).
InterMurph, regarding "Asus ROG GT-AX11000 router". That is the exact model I was looking at to replace the RAX120v2. Almost purchased last night. Your right about tech support not acknowledging the issue. Just got the, try this and report back. Nothing worked and even entering that the router was still initializing, they closed the ticket due to inactivity. I was waiting for a response from them! I really do not think that tech support follows up on the tickets if you enter any information. They wait for you to call them or open a chat.
I would like to see NetGear acknowledge the issue. I see I am not the only one with the router initialization.
The whole experience was frustrating. But I solved my problem by buying the Asus router, which has been completely reliable since I set it up.
- mudboneMay 08, 2021Apprentice
I had a major problem with Asus in 2015 with an X99 motherboard that fried the VRM in under two months. They refused to replace it and the support was terrible. Before that I had good luck with their hardware but that incident soured me on them. However companies that are as big as Asus usually have different divisions that design and build better products. Their router division may indeed be better.
- JTaylorIVMay 12, 2021Guide
While waiting to repalce the RAX120v2 with an Asus router I see that there is a new version of firmware.
For grins, installed the latest firmware, V1.2.1.22, did a reset (yes little recessed button with a paper clip, waited 30 seconds), reconfigured fresh. Still randomly reboots.
- ChichizolaMay 12, 2021Star
I tell you, it is not your device or firmware, its the brand. I used them for years. But, they've become an island at the expense of, what I guess, is their shrinking user base. I gave up on them.
- mudboneMay 13, 2021Apprentice
Thanks for letting me know about the firmware update and that it did not fix the disconnect problem. I shipped the RAX120v2 back to the Netgear store for a refund yesterday. I moved my old R7000 down to the basement as the main router and configured the RAX120v1 as the AP. I will upgrade its firmware this weekend to the new version just to see if anything changes. So far it seems to be more stable on the WiFi then version 2 was. I think for now I am going to wait on buying another router to replace the old R7000. I was looking at the WiFi 6e routers last night. I like the Asus GT-AXE11000 but for that much money it should have a 10 gig port on it:-)
- KillhippieMay 13, 2021Prodigy
I have the v1 and not had any of your issues, since both use the same firmware I would say its not the routers unless you were unlucky and got two duds, I have not had issues with my 120 in the last year and a half, I think maybe its your enviroment, maybe the power soirce you are plugginbg it into? Mine has never rebooted.
Also are you in the UK or USA? It seems USA users have more issues than UK users, maybe because we use PPPoE, also Armor makes the router unstable, and you have to make sure you have dialup turned to all the time and timout out set to 0. Dont use 160Mhz and have auto updates turned off. - mudboneMay 15, 2021Apprentice
Well you should consider yourself very lucky. I have now had both v1 and v2 and have had lots of issues with both but mainly with v2. There is nothing wrong with the power here or my environment and I live in the USA. I also do not use Netgear Armor and I am disabling the auto updates. Not sure I understand the "dialup turned to all the time and timeout out set to 0" suggestion. I am hooked to a Netgear CM1000 cable modem with 400/20 service. Also if I can't use the 160Mhz WiFi per your recommendation what is the point of me or anyone buying this WiFi 6 router? I returned the RAX120v2 router to the Netgear store this week for a full refund during the return window because it was unstable. The v1 seems more stable from what I can tell but it is far from perfect especially for nearly $400. My first support call was about performance on the Multi-Gig port. It would start out speed testing to 480 mbps down but then quickly degraded to 30 to 60 mbps. Trust me I really wanted both of these to work. I think the hardware has excellent specs and they are nice looking routers. However Netgear skimpped on the firmware development. Its clear that I am not the only one having these issues. I would have even been willing to fork out some extra money to get a stable firmware for these routers if it meant they would have worked correctly.
- KillhippieMay 15, 2021Prodigy
Because right now there are virtually no devices that use it, 80Mhz is more than enough. Factory resettin g is important, even Asus say to do that after a big change in firmware, you hold the reset in for about 20 seconds. leave to reboot the router takes about 5 minutes to completely boot. Set up as new, never with a config file as this brings low level code changes fronm the last firmware which may be incompatible. Also I'm not lucky, I know many users with 120's and they have no issues like yourself. I'm not saying you are not having them but to faulty units, In doublt it.
I know this router very well but cant really comment due to a NDA I signed, but I was in there from mid 2018 with the RAX120 beta testing leave it there. Its a very fast stable device. In internet settings set dialup to always on and idle timeout to 0 and press apply. Otherise the router goes to sleep! Back to 160Mhz yes you can use that with wifi 6E the 6Ghz band will support 160Mhz with no issues, 5Ghz not so much, and even the latest iPhones/iPads dont support 160Hmz. As I said few devices do and this will just make things worse as you clash with orther 5Ghz neighbours, leave it on 80Mhz on 5Ghz and 20Mhz on 2.4Mhz as forcing 40Mhz with any router reduces thoughput in busy areas with lots of routers using 2.4Ghz. - JTaylorIVMay 16, 2021Guide
My new (non-NetGear) router has been working great for the last 0 days 14 hour(s) 29 minute(s) 39 seconds. My NetGear router RAX120v2 would have re-initialized at least six times in the time period.
The RAX120v2 has excellent specifications, perfect for my home enviroment. I have nothing wierd that consumes a lot of bandwidth in my home. USA by the way.
I expected to unbox the router, setup a simple "initial" configuration and later look over the features and fine tune my enviroment. I could not get a stable setup with a simple inital configuration. I had expectations that the router would work and if I had issues, NetGear support would help. Level one support, try this, call back later. Nothing worked, they closed tickets with no resolution.
Truly appreciate all the suggestions to help resolve the issue with constant initialization of the RAX120v2 routher.
Just to recap, list of items that did not work for me.
* Reflash the firmware, reset the router back to defaults, manually reconfigure (do not use saved config). No change.
* change the wireless network channel to:2.4GHz - 11 and 5GHz - 161. No change.
* change MTU size, kindly select ADVANCED > Setup > WAN Setup. In the MTU Size field, enter a 1492 value. No change.
* change static DNS on the router to Primary DNS - 8.8.8.8, Secondary DNS - 8.8.4.4. No change.
* Try a different plug. Removed from an APC-1500 Smart UPS and connected to a different (non UPS) outlet. No change.
* Told by tech support to go back to revision levels of firmware. Unable to do, router errored revision too far back.Each time I would add notes to the NegGear service ticket. Only when I contacted NetGear support, via Chat, is when the would read the tickets. I was waiting for furter instructions, they closed the ticket due to inactivity.
* WiFi only using 40Mhz (2.4Mhz) and 80Mhz (5G)
* Disabled AX. No change.
* Tackled Layer 1, changed cables. No change.
* Installed the latest firmware, V1.2.1.22, did a reset and still no dice.
* Added fans to rule out thermal, as best as I could. Room where router was located, residential, room temp.
* Removed internet connection, turned off WiFi, only LAN connected PC, router still initialized.Experience, Employed (retired) by a large engineering firm for 31 years. Started with mid-range systems, IBM-36 with dumb terminals connected via twin-ax (PC's were XT and AT, non network at the time) to complex networks and servers. I know the terminology.
I probably, by some long shot odds, had two bad routhers. I did not want to try a third, went in a differrent direction.
My wife is not riding my back about the network. My life is better, she is happy.
If you get a good one, congrats. They are nice routers based on the specs.
Bye All,
:EOM
- ChichizolaMay 16, 2021Star
Similar experience. @DITCHNETGEAR
- mudboneMay 17, 2021Apprentice
I read your recent comment and it took me a little time to figure out how I was going to respond so here it is. First off you sort of gave yourself away with the comment "cant really commit due to the NDA I signed" which tells me your opinion is biased at best. Secondly I think your posts are kind of insulting. You can clearly see by reading the posts in this blog and many others that a lot of Netgear customers are having serious problems with the Netgear AX series routers. So please stop acting like its just something I am doing wrong because its clearly not just me. I have never written firmware for a router or any piece of hardware for that matter so I do not claim to be an expert. However I do have a computer science degree and have been working as an application developer for 23 years now so I am not stupid. Netgear has totally dropped the ball on the firmware for these routers and its a shame because the routers have great specs.
I looked for your suggested changes under "Internet" on my RAX120v1 router but because I am using it for an AP router its grayed out. When I have to factory reset it again, and I will, I will set it up as the main router at least temporarily to change those settings to see if it affects anything after I switch it back to AP mode. I have already factory reset the router twice now since I upgraded to firmware V1.2.1.22 and I am still having issues with the router. The newest bug I have been seeing with the last couple firmware versions is that all the devices are not showing up under the "Attached Devices" but they are showing up over on the R7000 main router as wired. Power cycling did not fix this so I factory reset it again. Very annoying.
I am willing to consider all suggestions but I am starting to think I may have to ask Amazon to take this one back to. I can't wait around for Netgear to decide to fix these problems. My wife and I both work from home and we can't be having our jobs disrupted by dropped WiFi connections. It disconnected her from her online church service this morning. This is intolerable.
Killhippie wrote:Because right now there are virtually no devices that use it, 80Mhz is more than enough. Factory resettin g is important, even Asus say to do that after a big change in firmware, you hold the reset in for about 20 seconds. leave to reboot the router takes about 5 minutes to completely boot. Set up as new, never with a config file as this brings low level code changes fronm the last firmware which may be incompatible. Also I'm not lucky, I know many users with 120's and they have no issues like yourself. I'm not saying you are not having them but to faulty units, In doublt it.
- FlyingSeminoleMay 31, 2021Initiate
Completely agree with you mudbone. There seem to be multiple people on this website that are either Netgear fanboys or paid by Netgear to make it seem like there is nothing wrong with their product. I have had all of the same issues everybody else here has had with this router and have done all of the steps as listed over multiple months. I have two friends that have this exact same router and have had the same issues. I even RMAed one of these routers to run in to the same issues. Techincal support is useless because they don't listen when you tell them it's not just the WiFi breaking, but also the wired ethernet connection. When I pay for a high-end product I expect high-end performance and not to be testing their software for them. Constantly having to fully factory reset a router is not an acceptable solution when it ends up having to be done multiple times a month sometimes. I will never be buying a Netgear networking product because of this experience. I have a 7 year old Netgear AC router and never had to factory reset it.
