MikeinMK
Dec 19, 2019Aspirant
Brennan BB1 cannot see my SSID
My router works fine and items like phones and tablets can connect to it. Recently I purchased a Brennan BB1 but when I try to connect this item it cannot see my SSID when it scans for available netw...
Dec 19, 2019Guru - Experienced User
I couldn't find much info about the Brennan bb1 for what wifi card it uses. When something works on everything but 1 device, it tends to be an issue with the device implements its wifi with newer technologies.. With that said, maybe you can get it working.
Something you potentially could try doing is:
1. set your wifi speed down on your 2.4ghz ssid. I've had IoT devices that needed the 2.4ghz speed set down before they'd work.
2. setup an open guest network. maybe something with security has it implemented wrong.
