MikeinMK
Dec 19, 2019Aspirant
Brennan BB1 cannot see my SSID
My router works fine and items like phones and tablets can connect to it. Recently I purchased a Brennan BB1 but when I try to connect this item it cannot see my SSID when it scans for available netw...
michaelkenward
Dec 20, 2019Guru - Experienced User
MikeinMK wrote:
The Brennan works correctly at another house with a different modem.
If it is possible, how about a reset on the Brennan?
Restarting it will not wipe out past settings from the old modem.
MikeinMK
Dec 20, 2019Aspirant
I've reset the Brennan several times and also rebooted the router. Somewhere (it I can find it) I still have my old modem/router, also Netgear. When I find it, I will try that one. If it works I can connect the Brennan to that one, everything else to the nighthawk.
