wifi-google
Nov 22, 2020Tutor
Bridge RAX120 with Google WiFi
Hi I have recently purchased the RAX120 hoping to improve the file transfer speeds over wifi. The setup I used before was Google WiFi with 4 points which gives great coverage to all the rooms but...
- Nov 22, 2020
Problem is that googles mesh system doesn't have an access point mode/bridge mode when using more than 1 mesh device.
https://support.google.com/wifi/answer/6240987?hl=en
you could go:
modem------google mesh ------mesh satellites
RAX120 (access point mode)
That'd let the google run as primary router and still give you the option of the RAX120's wireless
Nov 22, 2020Guru
Usually plug the modem into wan port on google router. Then on the google router connect its lan port to the wan port on the netgear.
The wireless channels can create interference with each other so make sure place them on channels far enough apart that they don't interfere.
wifi-google
Nov 22, 2020Tutor
Thank you plemans !
I tried this setup and it works really perfectly ! Didn't observe any affect on the performance comapring when worked with the Netgrear RAX120 as router (at least from the lasy 1 hour tests).
- plemansNov 23, 2020Guru
Glad it works for you how you'd like it!
