Jasond776's avatar
Apr 11, 2020
Bridged 802.11ax wifi routers - too slow!
Hi there,   I have two Netgear Nighthawk wifi 6 capable routers. My RAX40 is connected to a 600 Mbps cable modem. Speedtest at the modem indicates the full 600 Mbps as expected.   As I don't have...
  • plemans's avatar
    Apr 12, 2020
    What firmware is on the RAX40?
    do you have access control/traffic monitoring/qos? if so, try factory resetting the rax40 and reinstalling with just setting up the minimum service (internet connection and wifi ssid/password). Then try testing again.
    Testing in the same room, most of my ac devices can get faster than 300mbps out of an AC connection. My intel 9260 can hit 600-700mbps and my intel AX200 can hit >1gig over wireless if my connection is good enough.
    so focus first on getting the RAX up to speed prior to bridging.
