Giles_Gilbert
Dec 29, 2022Tutor
Bridging a RAXE500 and RAX10
I have a RAXE500 configured to share a SSID on all bands and am trying to connect a RAX10 in bridge mode to it. The RAX10 in bridge mode connects correctly when set to 2.4Ghz, but when set to 5Ghz it...
- Dec 30, 2022
SOLUTION: The router must be set to a channel in the non-DFS range for a bridge to work. Makes sense given that the DFS channels can be changed automatically. Bridges are supposed to be reliable and hence not subject to sudden changes.
michaelkenward
Dec 30, 2022Guru - Experienced User
In the wonderful world of network devices, "bridge mode" means different things for different devices in different contexts. In your case, I suspect that you mean what the manual describes as Router/ AP / Bridge Mode. Is that it?
If you compare the descriptions from "bridge mode" in your two routers, you may see that they describe different operations, wired and wifi.
Does the RAX10 offer a wifi bridge mode?
Maybe someone familiar with these two devices can step in.
- Giles_GilbertDec 30, 2022TutorYou are correct in that I am referring to the various modes of operation which include router, access point and bridge.
The RAX10 does indeed have these modes and I am selecting Bridge, entering the band I want, 5Ghz, SSID and password along with the security type that matches the main router.
According to the book it should work and it indeed does when using the 2.4Ghz band, but not when setup for 5Ghz.
I suspect something needs changing in the RAXE500s configuration.
Also, I have tried setting up different names for each band and explicitly using the 5Ghz name and still no connection.
Thanks!- Giles_GilbertDec 30, 2022Tutor
Minor update. I was able to connect the RAX10 in bridge mode to an old 802.11n router that I have, so that part is working. It must be something to do with the RAXE500 ... ????
