Giles_Gilbert
Dec 29, 2022Tutor
Bridging a RAXE500 and RAX10
I have a RAXE500 configured to share a SSID on all bands and am trying to connect a RAX10 in bridge mode to it. The RAX10 in bridge mode connects correctly when set to 2.4Ghz, but when set to 5Ghz it...
- Dec 30, 2022
SOLUTION: The router must be set to a channel in the non-DFS range for a bridge to work. Makes sense given that the DFS channels can be changed automatically. Bridges are supposed to be reliable and hence not subject to sudden changes.
Giles_Gilbert
Dec 30, 2022Tutor
Major Update: It appears this is a channel number problem. Dropping it to a very low channel number it appears to have started working, all be it slowly. Not satisfied to call it solved yet but on the right path.
