kevinm10
Jun 09, 2024Aspirant
BROTHER EASY SCAN TO EMAIL APP CONNECTION ERROR 03 PORT 80 443 Nighthawk AX4: RAX40 port forward
BROTHER EASY SCAN TO EMAIL APP CONNECTION ERROR 03 PORT 80 443 setup as port forwarding in/out with printer ip but printer errors with connection error 03 and proxy is disabled on printer. Anyone...
- Jun 09, 2024
After further research rebooted the router, after adding the port forwarding rules, and it's working.
Solved.
kevinm10
Solved.
- FURRYe38Jun 09, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
