Adsc14
Oct 19, 2020Aspirant
BT Fibre Using RAX80
Hi I have just had BT fibre installed to my house and I am looking to continue to use my RAX80 rather than the smart hub supplied by BT but I have no idea how to configure this as it needs to use W...
Adsc14
Oct 22, 2020Aspirant
michaelkenward I have the BT Full Fibre 900 package which they supplied with a SmartHub 2
michaelkenward
Oct 22, 2020Guru - Experienced User
Sadly,this still leaves room for confusion.
BT Full Fibre 900 says it is fibre to the premises.
Full Fibre | FTTP Broadband | Fibre to the Premises | BT
But the SmartHub 2 also claims to be a DSL modem/router:
BT Smart Hub 2 (097683) | BT Shop
This leaves us guessing as to how the SmartHub 2 connects to the Internet.
Do you connect through a WAN port on the back? In its usual in inimitable style, BT does not provide a picture of the working end of the thing.
If it is just a WAN thing, then ask BT for the details you need to feed into the router to connect it, and use the RAX80 instead. I'm afraid there are too many login routines for anyone here to keep track of them. That's BT's job.
You may find more BT users over on the BT Forum than there are here:
Welcome to BT’s official support community.
When you know what you need to get in, then the manual is the place to start.
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
