dwaynek
Mar 16, 2022Aspirant
bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
the latest firmware 1.0.4.102 won't allow me to change ssid/wifi passwords even after repeated resets. I finally rolled back to a previous version which works fine.
Mar 16, 2022Guru - Experienced User
Did you factory reset the router and setup from scratch after v.102 was loaded?
