dwaynek
Mar 16, 2022Aspirant
bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
the latest firmware 1.0.4.102 won't allow me to change ssid/wifi passwords even after repeated resets. I finally rolled back to a previous version which works fine.
CD_router_888
Apr 17, 2022Guide
Hi dwaynek ,
Did you use GUI or Nighthawk APP to config the Wi-Fi setting ?
If you used Nighthawk APP, which app version did you use ? iOS or Android ?
Thanks.
