jeadams
Apr 12, 2019Aspirant
BUG REPORT Nighthawk® AX12 RAX120 Router Firmware Version V1.0.0.84
Choosing option WPA2-Personal[AES] + WPA3-Personal encryption disconnects IPAD 2 running IOS 10.3.3
Must choose WPA2-Personal [AES] to stay connected.
Christian_R
Apr 12, 2019NETGEAR Employee Retired
Hi jeadams,
We recommend reporting vulnerabilities using the provided link: https://www.netgear.com/about/security/default.aspx
~Christian
- schumakuApr 12, 2019Guru - Experienced User
Christian_R - that's a bug, not a security vulnerability. Perfectly chosen subject by the OP 8-)
- kc6108Apr 14, 2019Luminary
Did you ever get this issue resolved? I'm interested in purchasing the RAX120 but not if simple test cases like this are present.
Also, the response you got from the moderator Christian_R was totally unacceptable and way off base. You should contact support if you are still encountering this issue. Make sure to reference this forum thread.
What I meant to state above was:
I'm interested in purchasing the RAX120 but not if Netgear's QA team hasn't bothered to document and execute simple test cases like this. A bug like this should have been caught weeks, if not months, ago.
