jeadams
Apr 12, 2019Aspirant
BUG REPORT Nighthawk® AX12 RAX120 Router Firmware Version V1.0.0.84
Choosing option WPA2-Personal[AES] + WPA3-Personal encryption disconnects IPAD 2 running IOS 10.3.3
Must choose WPA2-Personal [AES] to stay connected.
schumaku
Apr 22, 2019Guru - Experienced User
These old iPad 2 don't get any more updates. As a WPA2 device it has to associate the new RAX and run reliably.
mbze430
May 03, 2019Guide
Surface Pro 3 with the Marvell Wifi will not connect when set to WPA2+WPA3. Will connected fine WPA2 even with AX enabled.
- mbze430May 03, 2019Guide
Also for HT160, center valid channels are 50 & 114....
neither of those 2 channels are available when changing over to HT160
- schumakuMay 04, 2019Guru - Experienced User
Aehm, the many years old Surface Pro 3 does unlikley support a config for WPA3 (just like the mainstrem Windows 10 release which don't yet...).
Should you talk of the router radio setting, this system isn't alone - several devices are struggling. Could be a client as well as a AP problem.
- mbze430May 04, 2019Guide
True the Marvell doesn't support WPA3. However this new setting
lead one to think that devices that CAN authenticate via WPA3 will do so, if not it will fall back to WPA2. Which that is the case for Android devices that I have tested. When I have it set to that particular setting. My Android devices continues to connect via WPA2 even though it doesn't connect at WPA3. Which should happen as well in Windows or ANY other devices.
Which also hold true to this settingWPA-Personal [TKIP] + WPA2-Personal [AES]
if a device can't connect at WPA2, it will fall back WPA.
- schumakuMay 04, 2019Guru - Experienced UserSure, and that's what this thread bug report is about - some clients fail to associate if the RAX is set to WPA3+WPA2.
