Retired_Member
Oct 09, 2022Built in VPN with IPhone
I have a problem connecting my phone to Local network. I enabled built in VPN and DDNS on RAX 48 router. Then i downloaded the Smart Phone Config and exported to my Iphone. Followed these steps: ht...
iyang
Oct 13, 2022NETGEAR Expert
Hi Retired_Member ,
Do you install openvpn app in your iPhone ?
And do you put openvpn certification to your iPhone ?
Thanks.
Retired_Member
Oct 14, 2022on my iphone.
there's really no way to import a certificate. Also inside of Config file that i got from Netgear built in openVPN, it already has certificate.
