Kttiekat
Sep 11, 2020Guide
C7000v2 upgrade to....rax80??
i am thinking of upgrading to RAX80. on amazon one of the q&a says it will work with any modem. we have xfinity with cable internet service up to 1000mbps. what modem do you recommend to go with RAX80...
Kttiekat
Sep 11, 2020Guide
What if we replaced our current extenders with the eax80? Keeping the c7000 modem/router?
And if not, what mesh systems do you recommend? The wifi5 or wifi6 orbi?
Sep 12, 2020Guru - Experienced User
Kttiekat wrote:
What if we replaced our current extenders with the eax80? Keeping the c7000 modem/router?----Extenders rely on the router, so even though the extender is AX its running off an AC system so won't perform better than the AC devices.
And if not, what mesh systems do you recommend? The wifi5 or wifi6 orbi?---Depends on performance needs and budget. I have a lot going on at my place and an AC system it fine.
- KttiekatSep 12, 2020GuideHave you heard good things about the orbi router/modem?
Thanks for your feedback, I really appreciate it. I have a six week old and my brain is fried!- plemansSep 12, 2020Guru - Experienced User
I've used the orbi RBK53 and RBK43 system and both have worked great for me. I haven't used the AX series so far. Maybe in the future but I can't justify the cost right now. Plus I can hit 200mbps+ over wireless and hit gig speeds wired so it covers all my needs.
If you don't pay for gigabit speeds, the c7000 can be switched over to modem only mode. Then you can hook a mesh system to it without problems.
- plemansSep 12, 2020Guru - Experienced UserBTW good luck with the 6 week old. That age is challenging for sleep and patience :)
