newtomesh
Nov 28, 2020Aspirant
cable bundled voice services
will this router work w/ cable bundled voice services thru Spectrum/Comcast?
Which router?
Spectrum and comcast are 2 different companies and don't always support the same devices. Which do you plan on getting?
- newtomeshAspirant
I have had Spectrum for years (previously TWC) however i believe that Comcast bought them - not sure but Spectrum for sure. I have a Modem - Motorola TM 1602A MTA (that i lease thru them if that matters). I tried to install TP Deco M9 mesh and never could get it to work.
The tplink t9 is a pretty solid mesh system.
I'd be doubting the issue being a router/compatiblity issue.
You might check with spectrum on compatible modems with voice for your service. They have different compatibilites but should be able to tell you what'd work.
