carson_adkins
Jul 09, 2020Apprentice
cable connection from comcast to cax80 frequencies and internal logs
just curious about this stuff i have a bunch of errors in the modem Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during ...
dusteraz
Jul 10, 2020Aspirant
These are normal errors that occur when the device is ranging (when it is coming online/initializing). The TLV11 errors can be ignored, that just means there was something the in the cable modem config file that the modem did not recognize, the modem just ignores these and moves on.
carson_adkins
Jul 10, 2020Apprentice
well it doesn't seem like it is taking the gigabit speed so I thought that this could be the problem but I guess it's Comcast not provisioning my router right
- dusterazJul 10, 2020Aspirant
What are your speedtest results and how are you doing the speedtest? What I noticed is I get around 500 Mbps using the integrated speedtest but I an get 900+ fine with my PC that is wired directly.
- carson_adkinsJul 10, 2020Apprenticeyeah that's about what I get but my wifi 6 is the problem with this router it doesn't do wifi 6 speeds on 5ghz on my galaxy s10 when my Xfinity router did easily
