Kmf_1
Sep 18, 2020Follower
Can’t connect to device
Can’t connect to my device whenever I go to mywifiext it either won’t load or won’t tells me I’m not connected to a device I think i connected it to the wrong device how do I reset it and connect it to my in home device. All of my other lights on the device are green but the device one.
1 Reply
That address would be for a netgear extender.
Is that what you have?
Or do you have the D6000 you put in your signature?
Or do you have a different device since you posted in the Netgear AX forum.
