wwinter86
Feb 07, 2023Aspirant
Can’t set QoS above 1000?
I have a cable package with top download speeds of 1.1Gb (1130 Mbps) but I can not set my download speed to more than a 1000 on the router’s QoS page. I’ve also never been able to use the auto speed t...
Feb 07, 2023Guru - Experienced User
What NG router do you have?
Possible that the age of the router was designed before the age of multi gig speeds beyond 1Gb so you may not be able to configure anything. QoS isn't really needed for those speeds and besides QoS is for the upload link mostly. I would avoid not using QoS.
- wwinter86Feb 07, 2023AspirantI have the NETGEAR RAX200 connected to the Virgin Media Hub 4 as the modem.
- FURRYe38Feb 07, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first.
The main issue is that the isp modem only supports 1Gb on it's WAN port so i would be best to connect the modem to the 1Gb WAN port on the RAX200 and connect your 2.5Gb adapter to the multi gig port on the RAX200.
- wwinter86Feb 07, 2023AspirantYeah it is in modem mode may have to try to get them to send the newer hub 5 that had 2.5 Gb WAN
