GKL_SC's avatar
GKL_SC
Can access router thru phone WIFI using Nighthawk app but not from any of our laptops
Nighthawk AX6 AX5400 6-Stream WiFi Router (RAX50)   Windows computers and Android phone   We had about a 3 day power outage recently and it took them about a week to get the internet back up.   ...
  • GKL_SC's avatar
    GKL_SC
    Oct 18, 2024
    Just wanted to report that the issue was resolved when I switched from the guest network, I did not initially think being on the guest network was the problem because before the power/internet outage I was able to access the router with my computer being on the guest network.   I was able to get my printers back online again also but not sure if that was a direct result of changing from the guest network though it now seems likely.
