_aps
Mar 14, 2021Aspirant
Can an RAX200 inject all or part of an R7000 config?
I have an R7000 with access control enabled with MAC address of many devices configured. Is it possible that these can be injested by the RAX200? Thanks.
Mar 15, 2021Guru - Experienced User
Not sure w hat you mean by that. Are you trying to take the configuration from you R7000 and use it for a RAX200?
If so, please don't (at risk of your device). Just write them down or take a screen snip and then manually input them.
- _apsMar 15, 2021Aspirant
plemans wrote:Not sure w hat you mean by that. Are you trying to take the configuration from you R7000 and use it for a RAX200?
Thank you for answering. Yes, I was asking if I can take the configuration info from my R7000 and use it to get an RAX200 up and running. I was asking here to avoid "risking" the RAX.
Does anybody know if this works? Do Netgear support people read these?
I would be surprised (and, of course, dissappointed) were there not a way to extract the things that make sense (IP addressing, DHCP scopes, MAC addresses for access, etc.).
aps
