mrosen
Jan 03, 2021Tutor
Can i add a mesh system to RAX50?
I'm going horrible speeds in my basement. Is it possible to add a mesh system to expand coverage? Or would a different router suit me? Thanks.
Jan 03, 2021Guru - Experienced User
Are you wanting to add a mesh system like orbi or a mesh extender?
They're 2 different things.
- mrosenJan 05, 2021Tutor
I'm looking for recommendations on what I can do to get better wifi coverage throughout my house. The house is about 2,500 square feet. I tried an Orbi RBK20W but I didn't get good speeds. I thought it was wifi 6 but I believe it is not.
I went back to the RAX50 and placed it in the basement as that is now where my modem is.
The wifi 6 Orbi systems all look very expensive.
Thank you.
