wilcoxmj
Jun 30, 2021Aspirant
Can I add an external PoE Access Point to a RAX120
Hi, I have a RAX120 which provides great wireless signal inside my house - no complaints there. However outside the house I have next to no signal, which is challenging for my wireless security ...
michaelkenward
Jul 01, 2021Guru - Experienced User
wilcoxmj wrote:
My question is, can i add in an external AP with a PoE injector to one of the LAN ports on my RAX120? Unfortunately hard cabling out to my workshop isnt an option. And I am unable to move the RAX120 location, due to the proximity of the NBN entry to my house.
It might be safer, and simpler, to investigate Powerline Ethernet and, if you need wifi, to put a wireless access point on the remote plug. You can even by Powerline plugs that have a built in AP.
I have an Orbi in AP mode at the remote end of a Powerline network. Works fine.
wilcoxmj
Jul 01, 2021Aspirant
Thanks - not knowing a great deal about powerline, would it still be applicable if the sockets are on completely different electrical circuits? (I’m guessing the answer is no)
