jmjohu
Jul 30, 2020Aspirant
can i connect night hawk rax80 with mesh ax1800
can i use my RAX80 night hawk router with wifi 6
mk63 ax1800 mesh to connect for my house
Can you connect it via ethernet cable to the mesh system and run it in AP (access point) mode? Sure.
You can even connect it to the modem and run it in router mode and then connect the mesh system to it and run the mesh system in access point mode.
will it function as a mesh satellite? no.
Will it fully integrate with the mesh system? no.
- jmjohuAspirantcan i use mesh mk63 router as a mesh satellite
