superspartan300
Dec 03, 2022Initiate
Can I Enable Plex Media Server on RAX50 — Nighthawk AX6
I had a Nighthawk R7000 in the past which had Plex Media Server built in. I am surprised that a newer model years later does not have that feature. Is there a way to enable it on the RAX50 — Nighthaw...
- Dec 04, 2022
The R7000 didn't have plex built in. the only router netgear made with plex built in was the R9000.
None of the RAX devices have plex built in.
I'd recommend building your own plex server or even pickup a basic nas with those capabilities if you use plex a lot.
Once I switched to a dedicated server with more transcoding ability, plex ran smoother/better.
Dec 03, 2022Guru - Experienced User
The RAX50 doesn't support that i don't believe...
