birdus
Apr 16, 2021Aspirant
Can I Replace CenturyLink C1100T with AX4300?
I have a CenturyLink C1100T WiFi/Router and would like to completely replace it with a NetGear AX4300. Is this possible? If so, are there some directions/instructions I can follow that will walk ...
birdus
By the way, if it makes a difference, I have fiber optic. There's a box in the house (that goes from fiber to ethernet) that the C1100T plugs into.
- antinodeApr 16, 2021Guru
> [...] NetGear AX4300 [...]
"AX4300" is a speed, not a model number. Look for "Model" on the
product label. RAX45?> By the way, if it makes a difference, I have fiber optic. [...]
It probabaly does.
> [...] There's a box in the house (that goes from fiber to ethernet)
> [...]Thanks for that detailed description of your (unspecified) "a box".
> [...] that the C1100T plugs into.
_What_ on the C1100T is connected to your (unspecified) "a box"?
> walk me through it?Other than the router documentation? I wouldn't bet on it. If might
help if anyone could see the configuration of your C1100T. Possibly
interesting:https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-c1100z.html
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read?If your (unspecified) "a box" is connected to the [LAN/]WAN port on
the C1100T, then I'd guess that the C1100T is acting as a router-only,
so a Netgear router might be able to substitute for it. I'd expect
that CenturyLink could provide the required configuration details, even
if they don't want to help you configure you third-party device.- birdusApr 16, 2021Aspirant
My Netgear router is an AX6. The box which converts the fiber to ethernet is a Calix 716GE-I.
> My Netgear router is an AX6. [...]
Which part of 'Look for "Model" on the product label' was unclear to
you? The "product label" is the label on the product.> [...] The box which converts the fiber to ethernet is a Calix 716GE-I.
Ok. That's an ONT. You can think of it as a modem, if you want.
I'd guess that one of its (four) Ethernet ports should be connected to
the WAN/Internet port on your Netgear router.General advice: This whole Q&A thing often works better if every Q
gets an A. Look for "?".Still plenty of unknown router configuration details. You could try
connecting it instead of the C1100T, and see if its set-up wizard can
puzzle out the details.
