SuriKyu
Apr 18, 2022Follower
Can I setup Multiple BSSID on my Netgear RAX40
Hello I have 1 RAX 40 router at home. Now I want to setup Multiple BSSID on my AP. Does this feature support on RAX 40. If yes, how can I find manual to configure it Thanks in advance
microchip8
Apr 19, 2022Master
Multiple SSIDs are not supported. You only get one for 2.4 and one for 5 GHz. The same for the Guest SSIDs
