MoonBlossom's avatar
Mar 18, 2021
Can I use a Rax200 with Orbi?
We have RAX200 and over 80 devices. I think we need a mesh network. Can we use the Orbi or any WiFi 6 mesh system with the RAX200 router or do we need to get a mesh system and sell the router? Thank ...
  • plemans's avatar
    Mar 19, 2021
    Either could work. You could shut off the wifi on the rax or leave it on.
    I usually leave it on and just make sure its on different channels than what the orbi is using to prevent interference.
