Topper2k
Feb 02, 2021Aspirant
Can I use an MR60 as a satellite?
I have two Nighthawk MR60 mesh routers. Is it possible to use one as the router base station and the other as a satellite? And if so, how?
schumaku
Feb 02, 2021Guru - Experienced User
Not officially. Some hacks appeared in the net however.
- Topper2kFeb 02, 2021AspirantThanks. I've found some instructions on how to make the mr60 work as an access point. Is that what you mean? That looks like it requires a wired connection and a different SSID.
Can you point me to instructions to make it work like a satellite? I haven't had any luck finding them.
