Topper2k
Feb 02, 2021Aspirant
Can I use an MR60 as a satellite?
I have two Nighthawk MR60 mesh routers. Is it possible to use one as the router base station and the other as a satellite? And if so, how?
schumaku
Feb 02, 2021Guru - Experienced User
Not officially. Some hacks appeared in the net however.
Topper2k
Thanks. I've found some instructions on how to make the mr60 work as an access point. Is that what you mean? That looks like it requires a wired connection and a different SSID.
Can you point me to instructions to make it work like a satellite? I haven't had any luck finding them.
