ljp89
Dec 11, 2020Aspirant
Can I use RAX120 wi-fi 6 router to make into mesh system
Nnine months ago I installed a Netgear RAX120 router , replacing an R7000 , in my home of 2200 sq ft. 2 story. I have 2 additional different brand extenders with diferent addresses which creates some...
Dec 12, 2020Guru - Experienced User
2200sqft isn't a large home. A single router solution should cover it provided its centrally located and not made of brick, concrete, plaster lathe, adobe, or something else that blocks wifi.
What is the home made of?
Have you checked into a mesh extender? if you're only needing 1 satellite/extender, a better option might be going with a mesh extender.
I'm a fan of the tribands (ex7500, ex7700, ex8000). There's also the AX verison extender (eax20, eax80). I haven't used the AX extenders so can't attest to how well they work in comparison to the tribands.
- ljp89Dec 12, 2020Aspirant
Thanks to all who have responded. I will seriously consider adding the eax20 and or eax80 to my RAX120 router.
