Redtulips7
Mar 22, 2023Luminary
Can Laptop Cooler or AV Cooler Degrade WiFi Signal??
Hi I am always use Laptop Cooler underneath Router to keep it cool!! Today I replaced it with AC Infinity AIRCOM T9 Amazon.com: AC Infinity AIRCOM T9, Quiet Cooling Fan System 17" Top-Exhaust for R...
Redtulips7
Mar 23, 2023Luminary
According to LG G2 Spec yes it's stated WiFi 6 but TV detecting WiFi 6e Band besides 2.4 and 5 Ghz!!
Mar 23, 2023Guru - Experienced User
great if it is. Maybe they labeled something wrong on the spec sheet.
6ghz has less distance/penetration power than even 5ghz does. I don't think the fan should be putting off anything that'd block wifi but it itself might be attenuating the signal
- Redtulips7Mar 23, 2023Luminary
So I removed the T9 Cooler which actually made by Metal or Aluminum and retest it but results are same! with or without it. LG G2 twenty feets away in a another Room still getting 158/164 Mbps, with Sansung S23 Ultra getting 700 Mbps up and 600 Mbps down from 10 feets away which is not to bad!!!
- plemansMar 23, 2023Guru - Experienced User
Not to bad. But if signal doesn't change with/without it then it might just be the tv
