Redtulips7
Mar 22, 2023Luminary
Can Laptop Cooler or AV Cooler Degrade WiFi Signal??
Hi I am always use Laptop Cooler underneath Router to keep it cool!! Today I replaced it with AC Infinity AIRCOM T9 Amazon.com: AC Infinity AIRCOM T9, Quiet Cooling Fan System 17" Top-Exhaust for R...
Mar 23, 2023Guru - Experienced User
Great point. However as a proactive measure, running a laptop cooler under any router can help prolong HW life, stave off any HW failure contributed to heat. Heat can degrade or damage electronics or the life of the unit. Keeping additional cooling going is a benefit in most cases. Been running additional cooling on any router I put online for a long time. Also we can't be completely sure if and when the internal fan would trigger if the heat temp was met or exceeded. I'd rather not take a chance on that. 🙄
