Redtulips7
Mar 22, 2023Luminary
Can Laptop Cooler or AV Cooler Degrade WiFi Signal??
Hi I am always use Laptop Cooler underneath Router to keep it cool!! Today I replaced it with AC Infinity AIRCOM T9 Amazon.com: AC Infinity AIRCOM T9, Quiet Cooling Fan System 17" Top-Exhaust for R...
Razor512
Mar 23, 2023Prodigy
In the vast majority of cases, a router doesn't need additional cooling in in the specified environmental conditions.
Products like these will pretty much all go through a hot box test where they will place the product into a temperature controlled chamber with no active airflow, and run the product at full load at various temperatures.
This is why you will typically see specs like Operating temperature: 0° to 40°C (32º to 104ºF)
90% maximum relative humidity, noncondensing.
The main things that can negatively impact the ratings are if the device is exposed to direct sunlight where the casing can experience like when a car is parked outside on a sunny day. Other impacts can be if the product is mounted or placed in a position or angle in which the passive cooling was not designed for, or if placed on a surface that restricts natural convection for some of the vents, e.g., a router placed on a carpeted floor where the feel of ht product sinks into the carpet a little, and blocking off some of the bottom vents.
While it is hard to get datasheets for newer SOCs and radios, for many older 802.11ac items, it is not uncommon to see them have operating temperature ratings of -40°C to 100°C along with thermal protections where they should do a thermal shutdown, where the overheating part should shutoff until they get powercycled.While just like any device, it is not good for them to run at their max temperature 24/7, they should be fully stable within their temperature ratings.
Razor512
Mar 23, 2023Prodigy
Wanted to also add that it is common for many TVs, including high end ones, to have weaker than expected WiFi signals. This is due to the way they are built. The entire OLED panel (also applied to LCD panels), can be treated as an RF shield since the backing will be metal. Furthermore, with a thin bezel being a major selling point, there is no room to move a WiFi antenna into the bezel like you would see on a laptop, The end result is often a basic PIFA antenna near the middle of the back part of the TV that will likely end up mounted on a wall.
For WiFi router itself, while a metal laptop cooling stand will not block signals unless the client device is in a room directly below where the WiFi router is located. If there is a lot of metal around the router, then it can wreak havoc on the beamforming capabilities of the WiFi radios in it, which can impact the throughput at longer distances.
Edit: Also agreed on the additional cooling, lower temperatures will prolong the life of the product.
For Netgear devices, it seems they monitor the temperature of the SOC as well as each WiFi radio and if any exceed a temperature set in the firmware (unclear which specific temperature they specified), then the cooling fan will turn on.
Aside from that unlike enterprise or rack mount equipment with fans, a consumer focused device with a fan will likely prioritize noise levels over maintaining the lowest possible temperatures.
- FURRYe38Mar 23, 2023Guru - Experienced User
I know that for some TVs or placement configurations, WiFi may or may not be the greatest feature or option for TVs. If TVs have a ethernet port, might be recommended to use ethernet if the WiFi signal at the TV can't be utilized fully.
