mas1005
Jul 24, 2021Tutor
Can Nighthawk MESH use WiFi WAN uplink instead of ethernet?
I have a NightHawk MK63 dual-band mesh Wifi system. My cable modem ethernet port has broken. It is possible to configure the NIghtHawk Mesh WiFi system to use WiFi for the WAN uplink rather than et...
- Jul 24, 2021
No. its not.
What cable modem is it?
Is the wan port broken on the modem or on the router?
Jul 24, 2021Guru - Experienced User
No. its not.
