mas1005's avatar
mas1005
Tutor
Jul 24, 2021
Can Nighthawk MESH use WiFi WAN uplink instead of ethernet?
I have a NightHawk MK63 dual-band mesh Wifi system.  My cable modem ethernet port has broken.  It is possible to configure the NIghtHawk Mesh WiFi system to use WiFi for the WAN uplink rather than et...
  • plemans's avatar
    Jul 24, 2021
    No. its not.
    What cable modem is it?
    Is the wan port broken on the modem or on the router?
