TheComputerHyp
Dec 23, 2022Guide
Can only reserve 3 IP addresses
My router will only allow me to reserve 3 IP addresses. When I go to add a fourth, it deletes one of the 3 previously reserved addresses and adds the new one.
Comments or suggestions please.
- KitsapMaster
TheComputerHyp wrote:My router will only allow me to reserve 3 IP addresses. When I go to add a fourth, it deletes one of the 3 previously reserved addresses and adds the new one.
Do you have sufficient IP addresses available in the DHCP pool?
yes, boatloads!
- KitsapMaster
OK
Some pretty standard questions below.
What is the brand name and model number of the modem/ONT upstream of the router?
What is the version of the firmware you have on your RAX80? The "Latest" is not an answer. Only a version number will confirm the answer.
Are you trying to make this configuration change over a mobile device or a computer? If a computer, how is it connected to the router? Via Wi-Fi or an Ethernet connection?
Recently, have you powered down your router (pulled the power cord), waited for one minute or more, then restarted?
Does your ISP support IPv6? Do you have it enabled in your configuration?
For your existing IP reservations, are you using spaces or special characters in the device names?
When you last updated the firmware on your router, did you perform a firmware default reset and configure from scratch? Import a previous configuration file?
Arris SBG6580-G228
V1.0.10.140_2.1.46.1
Computer connected to router via Wi-Fi
Yes
Does your ISP support IPv6? Do you have it enabled in your configuration? IPV6 disabled
For your existing IP reservations, are you using spaces or special characters in the device names? No, but why does that matter. The user manual makes no mention of limitations for device names.
When you last updated the firmware on your router, did you perform a firmware default reset and configure from scratch? Import a previous configuration file? I did a firmware default reset and configured from scratch (learned of this design flaw the hard way when I imported a previous configuration file with the last FW update and couldn't connect to the internet)
- iyangNETGEAR Expert
- KitsapMaster
iyang wrote:Hi TheComputerHyp ,
What's browser do you use ?
Thanks
Primarily Firefox. I also keep IP address bookmarks in Edge as a backup.
Edge
