1GreenMachine
Nov 19, 2022Follower
Can Orbi or other netgear MESH devices be added to a Nighthawk RAX80 WiFi Router
I have a Nighthawk AX6000 AX8 8-Stream WiFi Router (RAX80)... I need to improve its coverage in the house can an ORBI or other netgear Mesh devices be fix this problem?
Nov 20, 2022Guru - Experienced User
You could add Orbi or MK mesh sytem in AP mode and disable the wifi radios on the RAX router. Or install a EAX series extender for help in getting more wifi coverage. Orbi or MK meshs systems would work indpendently of the RAX and will not integrate with it's wifi.
