jvhaslup
Oct 02, 2020Star
Can the RAX200 be configured as an access point?
Just getting fiber optic to the house today, and the tech has a CenturyLink 3960 (Zyxel C3000Z) modem/router combo in my garage. Due to the overall weak signal, I'm hoping to reconfigure my RAX ...
Oct 03, 2020Guru - Experienced User
The RAX200 does have access point mode and it works well in access point mode.
I doubt you can switch out the Zyxel C3000Z since centurylink would need a compatible modem/gateway. If you have one that is indeed compatible, then it might be a different.
