Liscome98
Nov 26, 2019Guide
Can we get a stable/working firmware for the rax 120
I am running the hot fix firmware currently..... and some of the functions don't work !!!! Along with the nighthawk app that my devices don't show up.... when am I going to have a working netgear...
- Nov 27, 2019
Update !!!!!!!!!!!!!!
Firmware V1.0.1.108 is out ..... go update !!!!!
I am running it as of 11/26/19 and its working .........
I hope this is a fix for all of us ... I can not find it on line ...but if you get the nighthawk app ...it will find the update ...
Let me know how it works for you ...
Thanks
PigletRider
Nov 26, 2019Apprentice
I have just 1 week left on my 45-day return policy with Best Buy for my RAX120. In desperation, I purchased a cheap ($89.00) AC router as a replacement as soon as the 5GHz radio degrades on me again. (It's been 24 hours since the last factory reset, one of many. So far so good.) I will then take that $500.00 paper-weight back to Best Buy for a full refund and just stick with the cheap AC router.
I'm hoping that Netgear, over the next week or so, will come out with a firmware update to address these issues. (I have a full 45 days from now to take the cheap AC router back if the hoped for update for the RAX120 fixes things.)
At this point, I just need my devices connected (and stable) to the Internet at the rated speed provided by my ISP. Netgear can keep all the fancy bobbles and trinkets. At this point, I don't care if they work or not. (I probably will later.) I just want consistent Internet access for my devices at speed... that's it! I'll settle.
- GabboCHNov 26, 2019Apprentice
I would take it back while you still can...
I've had my RAX80 for more than three months & theres been only 1 firmware update which didnt address any of the issues people are reporting and only change some localisation settings for Asian markets.
And before a firmware update, Netgear have to accept there is really an issue....
I replaced my €350 RAX80 with a €79 Wifi5 extender and have had no problems since.
Clearly all of the reported issues are with the firmware or hardware design of the RAX range but no sign of a fix for even some of the issues after many months.
