Liscome98
Nov 26, 2019Guide
Can we get a stable/working firmware for the rax 120
I am running the hot fix firmware currently..... and some of the functions don't work !!!! Along with the nighthawk app that my devices don't show up.... when am I going to have a working netgear...
- Nov 27, 2019
Update !!!!!!!!!!!!!!
Firmware V1.0.1.108 is out ..... go update !!!!!
I am running it as of 11/26/19 and its working .........
I hope this is a fix for all of us ... I can not find it on line ...but if you get the nighthawk app ...it will find the update ...
Let me know how it works for you ...
Thanks
GabboCH
Nov 26, 2019Apprentice
I would take it back while you still can...
I've had my RAX80 for more than three months & theres been only 1 firmware update which didnt address any of the issues people are reporting and only change some localisation settings for Asian markets.
And before a firmware update, Netgear have to accept there is really an issue....
GabboCH
I replaced my €350 RAX80 with a €79 Wifi5 extender and have had no problems since.
Clearly all of the reported issues are with the firmware or hardware design of the RAX range but no sign of a fix for even some of the issues after many months.
