Liscome98
Nov 26, 2019Guide
Can we get a stable/working firmware for the rax 120
I am running the hot fix firmware currently..... and some of the functions don't work !!!! Along with the nighthawk app that my devices don't show up.... when am I going to have a working netgear...
- Nov 27, 2019
Update !!!!!!!!!!!!!!
Firmware V1.0.1.108 is out ..... go update !!!!!
I am running it as of 11/26/19 and its working .........
I hope this is a fix for all of us ... I can not find it on line ...but if you get the nighthawk app ...it will find the update ...
Let me know how it works for you ...
Thanks
Christian_R
Dec 05, 2019NETGEAR Employee Retired
The release notes can be found on the product support site. I have linked the release notes for the firmware below.
https://kb.netgear.com/000061433/RAX120-Firmware-Version-1-0-1-108
Christian
Killhippie
Dec 06, 2019Prodigy
Even on the latest firmware, quality of service is completely useless on the upstream, the idle is high too at about 25ms downstream is always A but there are spikes of 356ms upstream, turn QoS off and you get a A or B is every time and idle goes back down to normal so something is really not right with QoS on this router.
- KillhippieDec 07, 2019Prodigy
Once again known port scan and dos attacks have stopped after just over 24 hours. Other logs seem to work fine. This is with router in AC mode for comptabilty testing, and a full factory reset after the update. There has been a lot of port scans in the last few days but having those logs die after such a short time is not gtreat if I am havinf Dos issues. Only way to get it to work is to reboot the router and I'm not doing that every 24-26 hours of there abouts. Also the difference between QoS on and off on a hard wired connection is odd too.. This is hardwired with QoS off: https://www.dslreports.com/speedtest/57213332 and hardwired with QoS on: https://www.dslreports.com/speedtest/56901687
Has anyone else on .100 and .108 seen the issue with security logs stopping after a short period (if you have those feaures enabled of course.)
- GabboCHDec 07, 2019ApprenticeI've not got an RAX120 but was logging with the RAX80 to provide files for the support case I have open regarding Wi-Fi connectivity problems.
I found maybe only 50-60% of the log files contained real data. The rest of the time I just download a empty zip file around 1.5mb.
I asked the support why this was happening (web interface not registering correctly the start logging request our perhaps the router soft rebooting).
As usually I got no answer just the request please make some more empty logs..- KillhippieDec 08, 2019Prodigy
Sadly I'm not surprised
- valerio1971Dec 12, 2019Aspirant
I have the same problem, QoS is unusable with firmware 1.0.1.108
- michaelkenwardDec 12, 2019Guru - Experienced User
Do you need QoS? How fast is your Internet connection?
Anything above 300 Mbps probably makes it pointless.
My internet connection is 200/20.
But I don't think I need a device feature to expect this to work well.
The activation of the QoS entails an E or F rating in upload, deactivating QoS the rating is C: it works in reverse.
