Mitcher
Oct 05, 2022Guide
Can we please get access to the RAXE500 BETA firmware coming after 1.0.10.86?
I have two of these routers. One in my home which powers two full-time remote workers (as well as two kids and all of their devices) and another in my AirBNB rental. At home, I also subscribe to both...
Oct 05, 2022Guru - Experienced User
v.86 is the most current version of FW and there is no beta version that we are aware of.
If you subscript to SPC and Armor, then DNS is preset by these features and can not be changed unless you disable them.
Are you using manual channels? What channels are you using?
- MitcherOct 11, 2022Guide
Thanks for the response. I did not know about SPC and Armor "locking" the DNS preset. That makes sense though.
At Home:
I am using channel 04 for the 2.4 network.
I am using channel 100 for the 5.0 network.
I am using channel 133 (psc) for the 6Ghz network.
All 3 have been set manually to the lowest congested channels based on a network app I run. The 5.0 network resets to "Up to 2400 Mpbs" after a day or two. I set it to "up to 4800" and hit save. I log out and back in and it is still there. I restart my router and it is still there. I check the following day and it is back to 2400. The same goes for my AirBNB router.
I have a few wi-fi neighbors but not many. My phone picks up two additional networks, both at low strength, at home. No neighbors for the Airbnb location.
My modem at home is the Netgear CM2000. The modem at my Airbnb is the Netgear CM1100.
Both my home router and Airbnb router are on the latest firmware: Firmware Version V1.0.10.86_2.0.40
Thanks,
Mitch
- FURRYe38Oct 11, 2022Guru - Experienced User
I did a factory reset on mine to check this and configured the following:
Used MS Edge. 4800 appeared to be default testing after the reset. I only enabled SC, OFDMA and changed the channels to what is seen here and applied the change.
- MitcherOct 12, 2022Guide
Now let's wait a day or two and have you log back in and see if it is still 4800 or not.
