tylerw243
Jan 11, 2020Aspirant
Cannot access routerlogin.net or 192.168.1.1 when RAX80 is connected to CM1200
Hi, I know this may seem like something simple, but im having an issue with my router, and i have finally after hours of troubleshooting and 4 different computers and browsers figured out the issue. ...
Jan 12, 2020Guru - Experienced User
Are you connecting more than 1 device to the cm1200?
are you using link aggregation with the cm1200?
Firmware on the RAX80?
are you able to access it, when it isn't connected to the cm1200?
tylerw243
Jan 15, 2020Aspirant
Thanks so much for the reply, heres the answers to your quesitions
▶︎No My router is connected to the first ethernet, I have tested it to see if it worked differently on the other ethernet but same issue
▶︎No,
"Ethernet Port Aggregation Status: Inactive"
▶︎Its currently V1.0.1.64 I know theres an update and I have auto update enabled, however, it still hasnt updated automatically and i cant get logged into it to update it. I cant get it to update from the nighthawk app either because I can only see my router when i use the connect remotely option. thats how i am able to see the firmware version is from the remote connection in the app
▶︎Yes I can log into it perfectly when its not connected to the modem. I have even double checked to make sure that im using the correct router IP address to access it as well
- plemansJan 17, 2020Guru - Experienced User
Here's what i'd try to do.
download the firmware for the router onto your pc.
unhook the router from the modem.
manually install the firmware to the router.
factory reset the router and reinstall it.
Try this. Maybe something was corrupt with the firmware.
