Carnegie
Apr 25, 2020Follower
cannot access the router after firmware update
I have had Nighthawk AC 3600 Tri-Band Wi-Fi Router R7960P working fine. Since the firmware update was available I updated it and now it says it is R8000 and it is not accepting my user name and passw...
Apr 26, 2020Guru - Experienced User
anytime you have issues after a firmware upgrade, a good place to start is factory reset the router and manually re-install.
have you tried this?
