Sjaak_B
Apr 14, 2021Aspirant
RNDU2000
My question: I need some support for my broken Netgear ReadyNAS RNDU2000. We used this product for years seamless. Now it is broken. The blue power-led is oké. But no network leds and no disk leds....
Sandshark
Apr 14, 2021Sensei - Experienced User
I suggest you just try his power suipply with your unit first. The symptoms you list could be the supply. If that's all it is, it's easy to replace.
If that doesn't do it, in case your friend is concerned: Other than any OS update you do, none of the NAS configuration is saved in the flash memory, so putting your drives in his unit (switching with power off) will in no way affect his volume or settings.
Apr 14, 2021Guru - Experienced User
Sandshark wrote:
I suggest you just try his power supply with your unit first.
I agree. And if that works, you can find compatible replacements for ~$25.
- Sjaak_BApr 15, 2021Aspirant
It was not the powersupply, but the Unit it self.
It was easy recovery by swapping one of the thisk in the same kind of RNDU2000 of a freind of my. The unit boot as useal and after this I store my data on a new temporarly store.
For now I am save :-)
Thanks for being with me freinds!
With kind regards,
Jack
StephenB wrote:
Sandshark wrote:I suggest you just try his power supply with your unit first.
