bemdblu
Feb 05, 2022Aspirant
cannot connect 2.4ghz like smart downlights etc
when i try to connect anything that is 2.4 ghz it will not find that like a smart downlight irrigation controller etc
Feb 05, 2022Guru - Experienced User
some more details help.
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to
4. when setting up the smart devices, is your device you're using for setup on the 2.4gh? For a properly coded IoT device, it shouldn't matter but poorly coded ones, it does.
- bemdbluFeb 05, 2022Aspirant
it is a TP link archer modem where the internet come from to the orbi rs350, it has the latest firmware
yes the irrigation controller is 2.4 ghz so are my downlights etc
regards
jack
- plemansFeb 06, 2022Guru - Experienced User
the trick is getting your phone on the 2.4ghz.
the orbi's can't be seperated.
options?
1. try turning down the 5ghz ssid signal and shut off the satellites. then move away from the router and disconnect, reconnect to it. Sometimes that'll get you connected to the 2.4ghz.
2. use a phone hotspot. Shut off the router/satellites and use a 2nd phone to turn on the phones hotspot with the same ssid/password as the router. go through setup. Then once its setup, shut off the hotspot and turn the router back on.
