smclayjr
Apr 09, 2020Aspirant
Cannot connect Google home to Nighthawk AX8 router
Model RAX75 AX5700 Used at home Firmware says up to date V1.0.1.70_1.0.20 Cannot connect google home to router.
Apr 10, 2020Guru - Experienced User
What issues are you having? Just saying it doesn't connect doesn't tell us where its failing in the process, whats going on, what you've tried, or pretty much anything. we need details to help you.
Firmware on your rax?
what modem are you using?
