smclayjr
Apr 09, 2020Aspirant
Cannot connect Google home to Nighthawk AX8 router
Model RAX75 AX5700 Used at home Firmware says up to date V1.0.1.70_1.0.20 Cannot connect google home to router.
smclayjr
Apr 10, 2020Aspirant
RAX75 is correct model but it isn't on the list above. It is an AX8. Serial Number 62719670A0861 Firmware Version V1.0.1.70_1.0.30 I am trying to connect my google home to the internet utilizing my Nighthawk RAX75 router. It was connected previously to a Linksys EA2700 router. I begin with the Google Home app on my iPhone 11. I click on setup device. I choose a home address. The app looks for and finds the google home device. I click next and it begins connecting to the google home. It says did you hear the sound. I answer yes. I agree to the legal terms and to help improve Google home. I tell it the device is in the kitchen. I then select the same wifi 2G network my phone is connected too. It tries to connect and fails saying "something went wrong. Says google home maybe setup but it could not communicate with my phone. It may require a small change to your wifi settings. Any help would be terrific.
Apr 10, 2020Guru - Experienced User
the google home (not mini) is compatible with 5ghz. Have you tried setting it up on that band?
what modem are you using?
- smclayjrApr 10, 2020Aspirant
5ghz doesn't work either. I get internet into my router from my ISP. There is no modem. Clarity Connect points their antennae to their broadcast location a few miles away. The google home worked great with my previous Linksys router.
- plemansApr 10, 2020Guru - Experienced User
Some of these wifi to the home setups have their own router running (corportate) or a small integrated router into the antenna box.
If this is the case, you could be in a double nat which can cause setup issues.
https://kb.netgear.com/30186/What-is-Double-NAT
have you checked with clarity connect to see if this is the case?
