lovely1979
Mar 09, 2022Follower
Cannot connect laptop to Nighthawk RAX43
I have an older Toshiba Satellite C850 (PSCBWC-05600J) with windows 8.1 which I cannot get connected to my wireless router. The wireless adpater is Realtek RTL8188CE wireless LAN 802.11n PCI-E NIC. ...
Mar 09, 2022Guru - Experienced User
Some of the older devices aren't able to "see" AX networks.
Its supposed to be backwards compatible but some still aren't.
You can try disabling wireless AX on the 2.4ghz for your router.
Or you could upgrade the wireless card or even add a usb wireless card.
